Old 10-06-2004, 10:09 PM
Jdooley Jdooley is offline
Question Blower Fan, High speed only
Does anyone know the location of the relay / diode pack which controls the front A/C blower speeds? I currently only have high speed available. This is for a 97 Astro with v-6 engine
Old 10-08-2004, 11:54 AM
ggcatt ggcatt is offline
Re: Blower Fan, High speed only
My '92 has the blower relay mounted under the hood, on the passenger side, in the engine compartment. There are two relays mounted, both black. The larger one controls the blower, with the lower three speeds controlled by one set of contacts, and the high speed by another. Likely the contacts are worn or corroded. Careful, this relay is powered, so disconnect your battery before disassembly and cleaning.
Old 10-08-2004, 03:56 PM
infinman infinman is offline
If you have high speed fan only, your problem is the blower motor resistor mounted on the heater box.
Old 12-17-2005, 12:45 PM
89&94 89&94 is offline
My 94 had same problem ,, finally motor quit completely.. come to find out the Motor Bearings were starting to seize... Replaced entire motor Assy for a little over $15 at Auto Z!
