Old 10-06-2004, 09:50 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
head leaking?
hey i traced oil back to my head...brand new on on my d16a6 motor and i wondering if the z6 head gsket could be causing this?....seem like its leaking on front left and right side of head...possible to leak oil there by drain wholes without colant getting in the mixture?
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 10-06-2004, 09:58 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: head leaking?
yes its possible, may not have torqued it all down good
Old 10-06-2004, 10:01 PM
Re: head leaking?
chamvber i torque it down good but i thnk i gonnan yank that head gasket out and just put stock gasket on....i torqued them down like it should i dont know what it could be besides the head gasket...also i just post on another topic, for some reason cylinder 3 on my d16 still leaking with new valve cover set.... you know what might cause that?
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 10-06-2004, 10:03 PM
Forunn Daberator
Re: head leaking?
you check the head to see if it was warped?
Old 10-06-2004, 10:06 PM
Re: head leaking?
cant be brand new man... why i am cant figure this out...that would been my first guess if wasnt new
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 10-06-2004, 10:21 PM
Forunn Daberator
Re: head leaking?
brand new as in from honda?
Old 10-06-2004, 10:33 PM
Re: head leaking?
ya...friend works there so he hook me up in the parts department...
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 10-06-2004, 10:46 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: head leaking?
check it anywho, ya never know
i'd say somethin went wrong with the gasket
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 10-06-2004, 10:52 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Re: head leaking?
I would of put the stock head gasket on in the 1st place,
but I have heard around these forums that with a Z6 head gasket it gives more compression or somthing,so I would of probably went for it too!
but that z6 head gasket really dont go to that motor,
that may be your problem,
but also,on your #3 cylinder leaking oil?
thats either a burnt valve or a oil piston ring burnt AKA blowby,
the best thing to do would be to do a compression check on it,
I had an oil leak in my #1 cylinder,changed my valve cover gasket,new gromets....& it still leaked,it soon ended up leaking out my air intake,
I done a compression check,it was my #1 cylinder,piston ring,
but the guy who done it said it could of also been a burnt valve,
(but in your case,you have a different head gasket,so it could be just that,)!!
but its kind of weird that its just leaking in the #3 cylinder
In the process of B00stin my D
Old 10-06-2004, 11:29 PM
Forunn Daberator
Re: head leaking?
He said #3 spark plug grommet is leaking, not valve.
Old 10-06-2004, 11:32 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Some people forget to read everything before they post....
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 10-07-2004, 01:01 AM
91civicDXdude's Avatar
Re: head leaking?
if the head is new and you're 100% sure you torqued it down correctly, then either one of three things is the culprit...
1. you *didnt* torque the head bolts down correctly
or..
2. your block needs decked. MLS head gaskets are far superior than their composite cousins, but they are a lot more picky about non-true surfaces...
or..
3. you didnt get all of the gasket material off of the block before installing the new gasket
Old 10-07-2004, 02:09 PM
Hybrid1990crx's Avatar
Re: head leaking?
I used a z6 head gasket on my 89 hatch. Worked great with no problems at all. I'm sure it would still be running if I didnt crash the car.
I saw the z6 is much better than the OEM composite crap gasket. And If you ever blow it again, you won't spend 3 hours with a razor blade and a can of carb cleaner.
Old 10-07-2004, 05:17 PM
Re: head leaking?
well i probably be going back to stock head gasket so i know its not the gasket if still leaks....and also cylinder 3 they all have close to same but this cylionder is a little higher do to oil being in it....so cant be the rings i dont think...there brand new and i place them in the right sequence....i guess i can retorque my head see what happens far as head leaking...but for cylionder three leaking i cna see it coming from groment when i dry it out...can see an oil line coming frome groment then just collecting at bottum of spark plug....i cant stand this motor giving me a head ache from day one
90 Honda CRX Si
-Red/Black
-B20B/b16
