| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
1986 GMC Vandura Transmission
Hello and thanks in advance for any help received.
We just bought a 1986 GMC Vandura Conversion Van with a 350 5.0 OD AT. We need to put in a new/used transmission and are wondering what additional makes (Chevy, etc...) and years might be interchangable with ours? Finding another exact 86 GMC transmission has been challenging. Thank You! Cristy |
#2 | |
Most decent transmission shops and autowreckers will know what will fit. Just tell them what it's for.
Stu |
#3 | ||
Re: 1986 GMC Vandura Transmission
Anyway, sorry back to your question. I think a TH350 will bolt right up. Hardly any conversion whatsoever. Linkage, cooler lines, cross member, even the drive shaft all fit like a charm. Only two things. The 700 doesn't have a vacuum modulator and the 350 does. So, no biggie, run a vacuum line down. The other thing deals with the throttle preasure cable linkage (hole sizes in their respective cases are different). But that's no biggie either. They make a kit, you just cut off the end of the plastic part of the cable housing on the transmission side with a tube cutter. Comes with directions and shows you just where to cut. Get the TH350 and not the TH350C. Less hastle and you won't have to mess with wiring the lock-up torque converter. (p.s. one disclaimer: in some States this procedure is against their smog laws and any certified mechanic/technician if found doing this could be found liable and possibly fined upwards to the extent of $10,000.00). |
