Old 02-15-2002, 07:27 PM
sbettati sbettati is offline
Send a message via ICQ to sbettati Send a message via AIM to sbettati
Angry 350Z... repainting......
Today i sprayed, as usual, the clear on my Gloss Alluminium 350Z... result.....
.....the clear "lifted up" all the fucked TS17, and now the body is laying in brake fluid.....
It's the first time i've painted something in TS17, i still don't know why the clear lifted that damn color. I used automotive two-components clear, as usual, i never had any problem with tamiya colors.
Probably, differently from other tamiya cans, TS17 REQUIRES PRIMER. I usually don't use primer with tamiya cans because there's no need to do that (this is what i tought before today).
Tonight i've tried to spray tamiya clear on another non-primed TS17 painted surface, with the same result.
Also my CLK-DTM is painted in TS17, but i primed its surface with tamiya primer, i hope this helps.
Tomorrow I'll try to spray on it some light coats of tamiya clear, befora applying decals, if this goes right (i hope) i'll place decals and then put a single coat of automotive clear, as usual.
If Tamiya clear, even sprayed on light coats over a primed ts17painted surface, screw up that damn gloss alluminium, another body will lay in brake fluid.......
Simone Bettati
Poor English but Better Modelling (i hope) :jump:
[email protected]
Now working on......
Both swimming in brake fluid....
Old 02-15-2002, 07:38 PM
Jay! Jay! is offline
Horizontally Opposed
Awww, man! That sucks!
Oh, well, live and learn (and post about it here. )
Hierarchy of Subaru:
(Click to see mine!)
Old 02-15-2002, 08:28 PM
Thing-A-Majig Thing-A-Majig is offline
oh maaan im sorry you had the panel lines painted already and everything geez that sucks. i plan on using ts-17 for my porsche with tamiya laquer... i hope i dont encounter the same problem
Old 02-15-2002, 11:45 PM
Guiddy's Avatar
Guiddy Guiddy is offline
Guiddy shakes his head and points to threads about using primer
Old 02-16-2002, 01:20 AM
primera man's Avatar
"P-Man"
DITTO
Ive said it several times....forget about clear coats. Spend the time on getting the paint perfect...rub it down with compound then polish it.
Have a look in the gallery of some of the ones i have done....not one is clear coated.
View All My Models Here.
Old 02-16-2002, 08:36 PM
XenoKryst XenoKryst is offline
Send a message via ICQ to XenoKryst Send a message via AIM to XenoKryst Send a message via Yahoo to XenoKryst
Hey Primera Man,
I've seen that most of your models have decals all over, so what is on top those decals if you don't use clear coats?
thanks.
Old 02-16-2002, 09:40 PM
"P-Man"
Originally posted by XenoKryst
Hey Primera Man,
thanks.
Once the decals are dry, about one day later i use Tamiya Wax on them to give them a polish. (Dont use rubbing compound.) The wax will not harm the decal , it will give them a nice low gloss look, plus it removes the water stain's and gives the car one good final polish
USED Nissan-350Z or NEW Mazda MX-5 Miata MaximumBandit Car Comparisons 3 07-11-2010 09:36 PM
Tamiya Nissan 350Z jetboy2004 Completed Projects / Gallery 6 04-08-2010 06:11 PM
Nissan 350z BORA2000 Completed Projects / Gallery 3 09-29-2009 09:21 PM
KMA repainted again! ChuckH Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 26 05-29-2001 01:19 PM
