Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-06-2004, 08:14 PM
chevygirlx chevygirlx is offline
Jeep shaking badly need advice!
My Jeep is a 2000 Cherokee Sport. Whenever I hit a bump at 55 to 60 mph it shakes very badly. It has gotten to the point where the front end starts shaking so bad that I have to come to a complete stop to gain control again. If anyone has any advice I would be very grateful!! Thanks!
Old 10-06-2004, 10:15 PM
Saudade's Avatar
Saudade Saudade is offline
Re: Jeep shaking badly need advice!
Check your alignment. Check the steering stabilizer.
Jack up the front (one side at a time) and shake the wheel (not too hard) and see if there's any looseness or play. It should rotate smoothly but nothing esle.
Old 10-07-2004, 04:19 AM
thinmints thinmints is offline
Death Wobble as we owners call it is something all have encountered at one time or another. if you look at other post you will see that it has come up alot and lots of usefull advice is posted read them and it should help you and your jeep
Old 10-07-2004, 06:49 AM
gtmud gtmud is offline
I too had the "DW" in my 2000 XJ, but it was after I put a 2" lift on it. Took it into get an alignment and it fixed the problem. Also check ALL of the componants in the front end, doesn't hurt to go through and tighten EVERY nut and bolt, especially the control arms and track bar. Good luck.
Old 10-07-2004, 10:37 AM
Alright thanks everyone I'll definetly give those things a try!!
Old 10-09-2004, 04:33 AM
Cam7 Cam7 is offline
My 93 XJ did same thing =Steering Stablizer Problem Solved.
Old 10-23-2004, 07:57 PM
00jeepcyndi 00jeepcyndi is offline
Unhappy death wobble
ok i have a 2000 cherokee sport and have gone thru this problem....we were told the steering stabalizer...wrong.....we were told alignment...wrong......you know what cured the problem of course after the jeep spent 2 months at the dealer with everyone just shrugging their sholders.....they replaced the brakes...pads and rotors...problem solved and sure enough it happend again we just had to have them turned. I now have found out that it is little secret from dodge that the rotors warp easily best thing to do if you can afford them is to replace the rotors with drilled or vented rotors less heat and we got ceramic pads.....i hope this helped you some i was soooo frustrated
Old 10-24-2004, 07:44 AM
Also try Bendix rotors, mine had 93K on the rotors before I replaced them with the bendix rotors, and carbon metallic pads. regained the stopping power I went too long with out.
Old 10-26-2004, 11:26 PM
lesifer lesifer is offline
Was this a commen problem with the earlier models as well? Like mid 80's.
Old 11-11-2005, 09:40 PM
raeuspius raeuspius is offline
Yes. I have had 86, 88 and now have 89. Track Bar is the cause of the DW's. This stablizes the front end drive and the overhead alighnment of the body. It links the axle and the lower portion of the driver side front engine mount. The loosenes takes only about 1/8 - 3/16 of an inch but gives upward almost a quarter turn on your wheel.
This makes you have to over correct and DW's happen on left curving and bumps. LOL love it!
Old 11-12-2005, 10:17 AM
JeepTrouble JeepTrouble is offline
Send a message via AIM to JeepTrouble
My 1990 did the wobble as soon as it hit 55, well i kept on driving it (BAD IDEA) and the tire blew from being so unbalanced and screwed up. Slid on the rotor 150 feet, got rear-ended and lost the rim too, never did find it, neither did the insurance people...... the moral of the story, Wobble= Bad
Old 11-15-2005, 02:22 PM
vamc's Avatar
vamc vamc is offline
To add on to everyone else, try replaceing the stearing shock.
Old 01-02-2007, 12:00 AM
jayz1791 jayz1791 is offline
Had the same problem on my 93 Cherokee sport. I had the front end shaking so much that I thought the windshield was going to shatter. I had several alignments done and none of them made a difference. The only thing that stopped the problem was replaceing the tires. Another suggestion was to look at the steering dampener.
Good luck
Jayz1791
Old 01-02-2007, 01:27 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Jayz, Welcome to AF and Happy New Year. Please check the date on threads before posting.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Closed Thread
