Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-06-2004, 07:05 PM
mcat39 mcat39 is offline
Question Should I replace my Timing Belt?
Has anyone had trouble with the timing belt on a '96 Izuzu Rodeo. I'm debating whether to get mine replaced. The car has 120,000 miles and I don't want to put to much money into it because I don't have too much extra money to spend on this and i'm not sure how many more miles I will get out of the car anyway. I've already spend $1,500 to rebuild the transmission and am kind of apprehensive about a mechanic taking apart an engine that works fine right now to replace a belt that may not have much wrong with it.
I'd appreciate any advice I could get on this! Thanks!
Old 10-06-2004, 08:56 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: Should I replace my Timing Belt?
its an easy job that you could most likely do yourself. Yes I would get it done. It would be better than getting stranded if it does break.
If you decide to replace it you should also replace the timing belt tensioner.
Old 10-06-2004, 09:33 PM
rodeo02 rodeo02 is offline
If you can handle the risk of being stranded with an inop truck, dont change the t-belt until the water pump starts to leak, then do the t-belt, tensioner & waterpump all at once. Flip side on that is, if you don't catch a small coolant leak & eventually overheat your 3.2, it will be toast.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 10-07-2004, 07:55 PM
highlandlake highlandlake is offline
I replaced the timing belt on my 97 rodeo last year. At 82,000 miles it was starting to show cracks that went about 1/4 into the belt. I wouldn't have trusted it to last to 100,000. If you are gonna do it, see the other thread about how best to hold it in place while lining up the timing marks. Good luck. Highland
