Old 10-06-2004, 04:03 PM
stangman01 stangman01 is offline
Question 84-85 accord info needed
hi hope someone can help i am working on a 84 accord with a 112 cid engine. the engine wont start it turns over fine but no spark. i tried replacing the coil with 2 new units but did not help. fuses are good new wires cap and rotor, plugs, filters and still no luck. i have also replaced the distributor and nothing. any help would be great.
Old 10-07-2004, 10:46 PM
mpumas mpumas is offline
Re: 84-85 accord info needed
Do you have power coming to the distributor on the bl/yel or bk/yel wire. It should be there anytime the key is on. (Not on ACC). The power goes through the coil then to the igniter and then to ground.
Old 10-08-2004, 11:10 AM
Thumbs up solved problem thanks
thanks for the help. it turns out both the ignitors on both distributors were bad. installed new one car running great. thanks again.
