Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-06-2004, 02:38 PM
bigboyisme bigboyisme is offline
MAF and other sensors, Coil Pack
Does anyone know what sensors can be cleaned and with what?
I noticed a cylinder was missing today and started pulling plugs off the coil packs to find the missing cylinder. As I did so, I noticed sparks jumping all over the place from the wire I pulled off the coil pack, is this normal? Or should there be no arcing at all? It turned out to be the #4 cylinder that isn't firing all the time. No codes or cel.
Old 10-07-2004, 06:11 PM
86TATpi 86TATpi is offline
You may need to check that coil pack to make sure it's still ok. Also check compression on the number 4 cylinder.
