Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-06-2004, 12:04 PM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
Angry throw out bearing problems!!!
If there is anyone with an answer to the following question either leave me a reply on here or get on icq and add me 104056640. Any ways
I have a 99 Saturn SC1 and theres a problem. The slave cylinder popped out of place where the throw out bearing hits the pressure plate.
when this happened i tried to put the slave cylinder back in place and the throw out bearing fell down inside the motor i guess .... How can i get this fixed?
Old 10-07-2004, 12:09 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: throw out bearing problems!!!
the throw out bearing rest on the transmission input shaft, unless it cracks into two it can't fall inside the bellhousing.
i highly doubt this problem is as bad as it sound. i myself would seperate the transmission and engine and look inside the bellhousing only if i knew for a fact something was in there(as there is no inspection plate)
ask the techs on saturnfans.com
this picture may help - http://www.saturnfans.com/photos/sho...php/photo/6935
heres how-to R&R the clutch -
http://www.saturnfans.com/forums/sho...threadid=23753
Old 10-11-2004, 11:56 AM
wilson05's Avatar
Well thanks, I knew it would be more simple than i thought to fix but theres one more questions.... How hard is it to get the tranny off? and How do i do it?
Old 10-11-2004, 10:33 PM
you don't need to pull the whole transmission, the R&R procedure above should give you enough room to see what you need to see. but if you do really want to pull the whole thing out - http://www.saturnfans.com/forums/sho...threadid=29795
Old 10-13-2004, 12:29 PM
wilson05's Avatar
Exclamation re throw out bearing?
Ok mabye i act like i know what i'm talking about but I dont believe i do but anyways the throwout bearing i was talking about that fell into the motor .... i believe what i was talking about that fell in wasnt the throwout bearing... it was a pin that when the clutch was pushed the pin pushed on something in the bell housing.... that pin is what fell inside ... should i try and fix it the same way?
Old 10-14-2004, 12:16 AM
don't worry, i know what you mean. seperate the trans and engine according to the clutch R&R and a bet that pin will drop right out, i'm just sorry there isn't a easier way to do it.
Old 10-18-2004, 01:36 AM
WOO-HOO, never so gain i'm wrong. there is an inspecton plate. normally its on the bellhousing facing the trans. but for the 1.9 liter, it is attached to the bellhousing underneth the engine. let me see if i can find a photo...
Old 10-18-2004, 02:08 AM
ok, this is all i could find. its on the right, haft-way covered by the timing chain cover.
http://www.saturnfans.com/photos/sho...p/photo/15134/
