Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-06-2004, 11:31 AM
dlw1969 dlw1969 is offline
Question Check Engine Code P0446
I have a 2001 Camry. The check engine light recently came on. I brought the car to the dealer to have them take a look at the problem. The dealer said the problem was that I overfilled the gas tank. When I got the car back the check engine light no longer came on.
About a week later, the check engine light came back on. I had not refilled the gas tank since I had taken the car to the dealer. I found out that Check Engine Code P0446 was the problem.
I have some questions concerning this particlular check engine code.
Is this something serious that needs to be taken care of right away?
What is the cause of this problem and can it be fixed by the dealer?
How much does this problem cost to repair?
Thanks for any help with this problem.
Old 10-06-2004, 01:06 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: Check Engine Code P0446
The error code P0446 means "EVAP System - vent control malfunction". This error code can be caused by any of the following :
Open or short in VSV circuit for EVAP
VSV for EVAP
Open or short in vapor pressure sensor circuit
Vapor pressure sensor malfunction
Open or short in VSV circuit for vapor pressure sensor
Malfunction in VSV for vapor pressure circuit
Vacuum hose blocked, damaged or disconnected
Charcoal canister malfunction...
I do think that this is something that you should look into having repaired as soon as possible to prevent further engine problems. Also, this might possibly hender your gas mileage and engine performance.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 06-13-2009, 08:04 PM
marcela112 marcela112 is offline
change the Charcoal canister this should fix it. If you have high milage this is your problem. Dealer price is a round $265, search ebay you could find it for $200.
Mike
Old 06-14-2009, 11:30 AM
quick69gto quick69gto is offline
Usually, if you overfill the tank once, it will soak the charcoal canister with fuel causing the need for it to be replaced.
I would try a used canister first (if you can locate one), if it fails, then buy a new one.
Old 06-15-2009, 01:56 PM
somick's Avatar
somick somick is offline
This thread is FIVE YEARS OLD!
Originally Posted by RIP
Please post back when you fix it so we all will learn something
