Old 10-06-2004, 11:06 AM
Rockymurf Rockymurf is offline
Can someone name this valve???
I'm looking for some info on a valve. It is fitted inside an annulus and is used to control air flow. it's similar to a butterfly valve, but with hole in it. Any information will be greatly welcomed, as i'm in a slight fix, thanks
Old 10-06-2004, 02:29 PM
383PhoenixAm's Avatar
383PhoenixAm 383PhoenixAm is offline
Send a message via AIM to 383PhoenixAm Send a message via MSN to 383PhoenixAm
Re: Can someone name this valve???
an annulus where?
Old 10-07-2004, 12:36 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
more info please, what type of car are we talking about? pictures? is the hole in the middle of the butterfly, to the side, or above? or elsewhere?
Old 10-07-2004, 02:03 AM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Frank
Old 10-07-2004, 02:53 AM
Well ,the valve is for a turbine. the proplem is i'm looking for pics.it consists of a number diamond shape butterflies evenly distributed around the circumference. I'm not too sure ye'll get much from that discription
Old 10-10-2004, 06:51 AM
5.0L_Import_Eater 5.0L_Import_Eater is offline
Its Called a....
The valve you are looking for, if it is the correct one I am thinking about, it is called a heater control valve. It works off of engine vaccum, and the heater switchboard inside your car. It controls nothing more than the tempature of the cabin air, and the rate at witch it flows. And guys, cut me a little slack, don't get mad at my user name, I own imports too. 95 eclipse gst, 91 talon tsi, and a 94 honda civic ex with a d16y8 swap. Mustangs4Life
