Old 10-06-2004, 09:53 AM
atomicpulse's Avatar
atomicpulse atomicpulse is offline
RPMs
I have a 98 S10 4.3L V6. When the engine is completely warmed up and in neutral, what should it be idling at?
Old 10-06-2004, 06:52 PM
Re: RPMs
any answers?
Old 10-06-2004, 07:40 PM
sector95 sector95 is offline
Re: RPMs
There should be an emissions decal located somewhere on the fan shroud, radiator core support or possibly on the underside of the hood near the latch. On that decal will be timing info, spark plug type and gap and idle speed.
mike
Old 10-06-2004, 11:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: RPMs
650rpms +- 25-50rpms
Old 10-07-2004, 03:20 AM
Re: RPMs
I would say mine idles at 525 to 550.. that normal?
Old 10-07-2004, 03:29 AM
BlazerLT's Avatar
AF -Advisor
Re: RPMs
Nope, too low.
Should be between 600-700
Check for a dirty air filter or a plugged fuel filter.
Old 10-07-2004, 08:28 PM
Re: RPMs
air filter was cleaned, fuel filter new. It runs perfect and its always idle at this rpm forever so i was just curious
Old 10-07-2004, 09:03 PM
BlazerLT's Avatar
AF -Advisor
Re: RPMs
Meh, could be the MAF but do you have any bolt ons installed.
Old 10-07-2004, 09:51 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: RPMs
Mine is at 600.
Old 10-28-2004, 01:03 PM
Re: RPMs
Alright on my throttle body there is a screw I can turn that will allow it more or less gas... any idea if i should turn the screw or not??
Old 10-28-2004, 03:14 PM
BlazerLT's Avatar
AF -Advisor
Re: RPMs
Don't start playng with things when you have no idea what they do.
Old 10-28-2004, 03:26 PM
Re: RPMs
well its pretty simple to see what it does, you turn it one way and when the truck is in idle the rpms go down, turn it the other and the rpms go up
Old 10-28-2004, 03:27 PM
BlazerLT's Avatar
AF -Advisor
Re: RPMs
do you know what it is adjusting?
Old 10-28-2004, 03:34 PM
Re: RPMs
the position of the blade in the throttle body when the truck is at idle, it moves the part that the cable from the gas peddel connents to, thats the best way i can explain it to you
