Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-06-2004, 08:47 AM
MyOldJimmy MyOldJimmy is offline
Outside Temprature display not working
I have been lucky in fixing most of the problems on my used 95 jimmy. However only one thing is haunting me still. I can't seem to figure out why the outside temp reading is always showing as "SC" or "5C". Occasionally it displays 140 degrees.
If I change the temp. sencor, will this fix the problem or is this a bigger issue than that?
Please help....
Old 10-06-2004, 08:55 AM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Re: Outside Temprature display not working
I can almost guarrantee it's your sensor.
You can do a check by unplugging the sensor from the radiator core bar (in the middle of your grill). If the console displays "OC" (it should) then you know it's the sensor.
p.s. $21 from gm dealer
Old 10-06-2004, 08:59 AM
THank you, I'll give that a shot.
