Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-06-2004, 01:13 AM
DBSS_Gohan DBSS_Gohan is offline
Send a message via AIM to DBSS_Gohan Send a message via MSN to DBSS_Gohan Send a message via Yahoo to DBSS_Gohan
Z31 Recall.
Ok, I was wondering, has anyone had the Z31 fuel injector recall done on there cars? I hear, if I have it done, Ill get new fuel rails, all new injectors, a new fuel filter, all sorts of good stuff, and I think I can work it out with them for them to change my valve cover gaskets in the process. But Iv heard some people have had wiring issues, and problems after they got there cars back from the dealership, then the dealership blamed the age of the car.... But I would kind of like the new stuff... And I was thinking maybe they could look at my steering while they were at it possibly cheaper too... I was hoping at least... Anyway, what should I do?
Cars:
1986 Nissan 300ZX N/A
1989 Mazda RX-7 GXL N/A
1984 Toyota Corolla SR5/GT-S Conversion in progress.
Bikes:
1980 Honda CX500
1994 Honda Nighthawk
"We race together, we ride together, we die together." - Linwood
Old 10-06-2004, 01:21 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Try here ---> www.z31.com
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 10-06-2004, 12:50 PM
Cam1970 Cam1970 is offline
Re: Z31 Recall.
First check to be sure if the recall has already been done - going to the dealership with the VIN would be a start. At this stage, most of the cars have already had the recall done. The electrical problems could also depend on whether or not your car has already had some electrical work, where a prior owner may have jerryrigged the wires to begin with.
Dan's Beast....see pics at members.cardomain.com/cam1970
Old 10-07-2004, 12:27 AM
Karen512's Avatar
Karen512 Karen512 is offline
Send a message via AIM to Karen512 Send a message via Yahoo to Karen512
NHTSA CAMPAIGN ID Number: 95I006000
Make: NISSAN
Model: 300ZX
Year: 1985
Causing Fault : FLOODS,LEAKS
Resulting Fault : FIRE, FLUID,ELECTRICAL,GAS(LPG),GASOLINE,OTHER
Component: FUEL:FUEL INJECTION SYSTEM
Manufacturer: NISSAN MOTORS CORPORATION
Year of Recall: 1995
Type of Report: Vehicle Improvement
Potential Number of Units Affected: 1
Summary:
NISSAN DEALERS WILL REPLACE THE FUEL INJECTORS AND RELATED HOSES OF THE AFFECTED VEHICLES.
SYSTEM: FUEL; FUEL INJECTION SYSTEM.VEHICLE DESCRIPTION: PASSENGER VEHICLES.DESCRIPTION OF PROBLEM: THIS IS NOT A SAFETY RECALL IN ACCORDANCE WITH FEDERALREGULATION 573. HOWEVER, IT IS DEEMED A SAFETY IMPROVEMENT CAMPAIGN BY THEAGENCY. THE CAMPAIGN WILL REPLACE THE FUEL INJECTORS AND RELATED HOSES OFAFFECTED VEHICLES WHICH COULD LEAK.CONSEQUENCE OF PROBLEM: FUEL LEAKS IN THE ENGINE COULD RESULT IN A FIRE.NOTE: NISSAN HAS DECIDED TO CONDUCT A SAFETY IMPROVEMENT SERVICE CAMPAIGN TOREPLACE THE FUEL INJECTORS AND RELATED HOSES WITHOUT CHARGE. OWNERS CAN CONTACTNISSAN AT 1-800-647-7261.
I wonder if they will still honor this recall after so long?
2004 SRT-4
1998 GMC 2500
1996 Eagle Talon TSi AWD Turbo
1993 Eagle Talon TSi AWD Turbo
1985 Nissan 300ZX Turbo
1990 Nissan 300ZX Twin Turbo
Past Z Cars Crew
Old 10-07-2004, 12:53 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Z31 Recall.
yep... as long as it hasn't been done before you should be good to go!
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 10-07-2004, 09:17 AM
BrandyDan BrandyDan is offline
Re: Z31 Recall.
Just remember that the dealership will work on the parts for the recall separately from anything else. Just because they will have the car up on a lift does not mean that they will put in 'all sorts of good stuff', as well as change gaskets and then steering...they're all very different things. Wiring should have nothing to do with anything, too. The reason for the recall was because too many of the cars were failing, or even bursting into flames. Steering and gaskets don't actually fall under that category.
See if the dealership will do a 'courtesy check' of the above, then if I were you I'd get quotes, since sometimes some of the work (outside of the things covered under recall) can be done cheaper at even a Pep Boys, Sears or Auto Zone, and still be covered under some sort of warranty.
