Old 10-05-2004, 08:51 PM
Abell255's Avatar
Abell255 Abell255 is offline
Send a message via AIM to Abell255
S*** , System help!!
My friend just got infiniti's with tweeters, he wired them to a rockford 2 channel amp through crossovers. With some sony ( dumb ) deck that was like 200$. Anyway, they work great, but he also purchased 1 audiobahn awt12( i'm not sure of the model, but its ~600rms.) With an audiobahn 800t amp. Which i think is 2 ohm stable, he says. Anyway, in order to get the pwr, gnd, remote to both amps, he used T's to split them. He was bumpin for a day, and the next he was crying. He said WTF, and i checked the T's, and the one that carry's the pwr current was F'd. It splits(obviously), but the one going to the spkr. amp is fine, but the one going off to the sub amp was blown. I checked the ground, it was to a bolt in the trunk, pretty good. He wired the sub, which is dual 4-ohm parallel to get a 2 ohm load. Anyway, why did it blow the fuse? And why not the one on the main pwr lead from the batt itself?
K, now let's forget all my questions/stuff i said their, and i'm wondering why would/could this happen in the first place? The amp would go into PROTECTION right when the car was turned on. That's obviously not good. He said it never got hot. Just went off. I thought, shit, is it wired to a to low of an ohm. But its not....2 ohm, which is stable for that amp. So i have no clue. could it be a setting on the amp itself? Why didnt it blow the fuses on the amp? Only the one in the T? I'm totally 110% clueless! Help me asaP! tHaNkS
-Bell
Old 10-05-2004, 09:08 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: S*** , System help!!
what size is the fuse in the distro block? (the 't')
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-06-2004, 10:12 AM
Abell255's Avatar
thanks! it was way to small. All fixed.
