View Poll Results: old milk looking
blown gasket 0 0%
cracked head 0 0%
Voters: 0. You may not vote on this poll
Old 10-05-2004, 08:07 PM
Primeshot Primeshot is offline
Unhappy Help needed quickly 94 cavalier
theres a leek some where in my head, screwed head or gasket, leaking radiant coolant into my oil gurgitated milk looking.
Old 10-06-2004, 04:07 PM
public's Avatar
public public is offline
Re: Help needed quickly 94 cavalier
Drain the oil and coolant. Remove the head. Clean the mating surfaces well. Check the head with a straight edge. If it is flat, reinstall. While you have the head off you may want to change the crank position sensor and the oil sending unit. Extra $20 but it is a lot easier to do with the head off. And these componients can fail and shut down the motor. Good Luck.
Old 10-07-2004, 06:37 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You forgot to tell him to replace the gasket.
The coolant won't have to be changed unless it has oil in it which I doubt it will.
Drain the oil ASAP so the corrosive anitfreeze doesn't damage your seals.
Old 10-07-2004, 03:23 PM
public's Avatar
I should hope that if he/she can get the head off. He/she would have the sense to replace the part that caused all the headache. And you should drain the coolant to prevent so much pouring down on the lifters and such. While it is out, why not go crazy and spend $10 for new coolant. But you are correct, it could be reused, just inspect for oil and then strain out any debris. Expect this job to take 6-8 hours for a novice. Again Good Luck.
Old 10-07-2004, 03:26 PM
BlazerLT's Avatar
AF -Advisor
Shouldn't take that long really on a 4 cylinder.
