Old 10-05-2004, 05:46 PM
edthead edthead is offline
Question 1989 PA won't start sometimes
Car will start with a shot of ether but stops when ether is gone. Sometimes the car will start and run but just for a little while. Hooked a fuel gauge to the fuel rail. 42lbs pressure drops to 38. Hooked up a timeing lite. Flashes at all times when cranked. Changed crankshaft sensor, plug wires, no check engine lite. Need to check computer for codes. What would cause computer to turn off fuel injector signal?
Crankshaft sensor, Camshaft sensor, ???
Old 10-06-2004, 09:41 AM
piranha piranha is offline
Re: 1989 PA won't start sometimes
I am having the same problem with my 93. are you having electrical problems? nothing in my car works. except the allarm witch I need to disable before I can check codes, but I thought this site might help you. http://www.geocities.com/dann8785/se...nginesoon.html
well good luck if you do figure out what is wrong with yours post it back on here.
Old 10-06-2004, 08:18 PM
RLS10315 RLS10315 is offline
Send a message via AIM to RLS10315
Maybe check the IAC i had a problem with my buick to where it wouldnt start unless i pumped the gas a little bit and had to keep it running by holding the gas. I had a dirty IAC so maybe give that a try
Old 10-09-2004, 06:41 PM
buickmastermind's Avatar
buickmastermind buickmastermind is offline
Talking :):):)
Check to make sure the Catylitic Converter or the muffler has plugged up. to do this, simply disconnect the exhaust near where the Oxogen sensor is located. It is real simple, two bolts. 15mm, deep socket
Old 10-09-2004, 07:16 PM
public's Avatar
public public is offline
A bad oil preasure sensor will cause this. If the module or ECM thinks you have lost oil pressure it will cut off the fuel. This saves you from expensive oil related failures. The IAC is also a good thing to check. It will not shut off fuel but can cause rough idle problems. Good Luck.
