Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-05-2004, 04:48 PM
superman0604 superman0604 is offline
Skunk II Intake Manifold
I am thinking about getting a skunk 2 intake manifold for my non vtec ls. Does anyone have one installed and what is your opinion. Does it give noticable horsepower and torque increase, and how hard is it to install?
Old 10-05-2004, 05:05 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: Skunk II Intake Manifold
what other mods do u have?
Old 10-05-2004, 05:49 PM
Cat back exhaust, high flow catalitic converter, ceramic coated headers, 10.3 mm spark plug wires, iridium spark plugs, drilled brake rotors.
Old 10-06-2004, 04:25 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
dont waste ur time on that manifold or any manifold for that matter unless ur plan n on go n turbo. u will loose horsepower if u slap on that manifold. and it's even worse since ur put n it on an LS
www.MEDIUMRACING.com
Old 10-06-2004, 04:35 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
most aftermarket intake manifolds only produce power high in the power band... high as in above 8000 rpm. I've seen them installed on gs-r and type r and the dyno only shows gains after something like 7800 so putting it on an LS with out any other engine mods is foolish. if anything build up the engine with that money first so that you can make a high revving engine then put the IM on.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 10-06-2004, 07:24 PM
What would give me the most horsepower for the money? Besides turbo and nos.
Old 10-06-2004, 11:17 PM
CAMS will give u power!
Oki, i also have an LS. Do this setup and u will be hitting mid 14's all day naturally aspirated. this is the setup im currently doing:
-CROWER 62404 stage 3 cams with Crower valvesprings and retainers
-PR3 Pistons (pistons from 99-00 civic SI) or ITR pistons (u will need to have ur LS rod's shaved a little bit to fit the type r pistons. the PR3 pistons that come in the b16 motor will fit right in the LS rod without any modifcations. it will also yieled a higher compression ratio which is a +)
-Adjustable cam gears to tune the cams
-Intake, Header, and full exhaust
-Adjustable Fuel presure regulator (need to tune motor once cams are installed)
-some type of fuel managment computer i.e. piggyback fuel controller like an APEXI SAFC or a stand alone unit like HONDATA, UBERDATA, etc...
-B16 Transmission (Best bang for the buck u can buy
when ur doing the cams, u might want to get the head ported and polished and do a valve angle job on it. that will give u an extra kick in ur pants.
i have all of these mods in my car with the exception of the cams ( i have the corwer stage 2 62403 cams. i still need to get a B16 tranny and pistons in my block.
im gauranteeing a mid 14 second car with these mods + TUNING!
Old 10-07-2004, 09:02 AM
b18 ls's Avatar
b18 ls b18 ls is offline
Banned
This is a great setup for a ls, but the stage 3 cams are race cams. They might not be that good for a daily driven car. I'm not sure though.
Old 10-07-2004, 03:05 PM
these cams are pefrect for daily driving. there might be a small lope at idle but it's very streetable.
Old 10-07-2004, 03:27 PM
What is the horsepower difference between stage 2 and stage 3.
Old 10-07-2004, 08:49 PM
stage 2 is supposed to give 12-15 whp, stage 3 gives 18-20 whp. i think those r the numbers. check out crower's website for the specs on the cams
