Go Back   Automotive Forums Car Chat > Subaru > Legacy / Liberty / Baja
Old 10-05-2004, 04:32 PM
tommyboy6 tommyboy6 is offline
car won't start
i have spark and fuel, but it won't start. what is the last ingredient.
Old 10-05-2004, 06:00 PM
Will2 Will2 is offline
Re: car won't start
I don't know what the last ingredient is but you might have fuel but is it getting to the carb/throttle body. Meaning fuel pump, water in the fuel or fuel pump relay.
Old 10-05-2004, 07:42 PM
Re: car won't start
i overheated it like a month ago and it quit running as i was driving and the antifreeze steamed everywhere. after further inspection, my timing belt was broke as well as my water pump. i replaced them both and now it won't start. everything seems fine now, it is not seized so i don't know what is going on. i hope that this is enough info. also, sometimes while i am turning it over, it will crank and crank, not start, and then it will stop and then continue cranking. i hope that that helps. thanks.
Old 10-06-2004, 04:05 PM
Re: car won't start
Sounds like the starter is 'ka-put'. Have you tried getting a push?
Old 10-08-2004, 11:25 PM
mike_dmt mike_dmt is offline
Re: car won't start
who put on the new timing belts? sounds like its off a cog or two.
Old 10-09-2004, 02:34 PM
Re: car won't start
well i figured out the problem, it was that the timing belt was off and now everything is great, thanks for all of your help.
