Have a jetta gls 97 with auto tranny. About 2 months ago, got engine light on and the car would run real slow. It was going on & off for several weeks and for the past 3 weeks, it is continously on. Had the codes read and it popped up as:
P0763 (shift solenoid C Electrical), P0715 (input turbine sensor circuit malfunction) on the net I also found these codes reflected as P0763 (solenoid valve EV3 - N90) P0715 (trans vehicle speed sensor (G38) No signal - interruption in signal) What does this means and what parts do I need to replace. The car runs fine except it doesn't seem to shift into 3rd gear because the RPM shoots above 4k when it goes above 55mph. |
Re: Error codes P0763 & P0715
It's possible the P0715 is just a bad sensor, but the P0763 is more concerning as it is probably a bad internal shift solenoid or wiring. It is probably in limpp mode & willnot go into overdrive.
Thanks. Do you know what is the part number for the sensor and where it is located ( input turbine sensor ). If you have a diagram would be beneficial.
Sorry, I don't have that transaxle info.
I am getting error codes P0715 and P0722. What is the name of the sensor on the trans that your are suggesting to replace for error code P0715???
