Old 10-05-2004, 01:55 PM
huminski's Avatar
huminski huminski is offline
Is my locker breaking?
I have a 2004 with a 5.3 and the locking rear. About 17000 miles. Two or three times now, when making a left turn at slow speed, like into a driveway, the locker will lock and not release. You will feel the truck drag and hear the tires dragging because the locker is locked. It will release eventually when the truck is straightened out. The last time this happened it made more noise than usual when disengaging. Should I have this checked out (still under warranty) or is it normal?
Steve
2004 2WD 5.3 Xcab StepSide
Old 10-05-2004, 07:13 PM
gremlin96 gremlin96 is offline
Re: Is my locker breaking?
still under warranty. why are you asking take it in for a check up. it should not cost any thing.
Last edited by gremlin96; 10-06-2004 at 08:32 PM. Reason: auto subscription not wanted
Old 10-05-2004, 10:14 PM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
Everything you mentioned sounds normal to me. its a locker...JJ
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
Old 10-08-2004, 08:56 PM
jabowles72 jabowles72 is offline
hello huminski I have a 2000 silverado Z71 and the rear end just started the same locking problem as yours and its not normal or it would have been doing it all along sucks for me I have no warranty so when the dealer tells you what is wrong with yours it would be very cool and helpful if you can post it are e-mail me thanks alot
Old 10-10-2004, 01:16 AM
RyanbabZ71 RyanbabZ71 is offline
did you check the fluid level?
Old 10-12-2004, 09:24 PM
I got under the back of the truck pulled the fill plug to check and my finger was not long enough the owners manuel says from 5/8 to 1 5/8 from the fill hole I am going to try again I found online where a guy talked about using an allan wrench to stick in the hole to find the level
Old 10-13-2004, 12:50 PM
allen wrench works great.
