Old 10-05-2004, 12:41 PM
kevin73 kevin73 is offline
how to get "service engine" codes
ok, i admit that i dont know a lot about cars in general. but i have a 2000 chevy s-10 2.2 with 77,000 miles. about two months ago the "service engine soon" light came on, and then went off the next day. this happened about once a week until last week. since then it has stayed on constantly. it drives the same, except lately it is very loud when over 70 mph.
so to make a long story even longer. is their a way that i can find out why my light is on without paying someone $75 , just to hook it up to a computer?
thanks.
Old 10-05-2004, 02:43 PM
busa_4 busa_4 is offline
you can either spend the 75.00 for someone to scan it or buy an obd II tester and scan it yourself. i bought a cheap tester for 120.00. but if your not a car guy your better off spending the 75.00 for a mechanic to scan it or find a friend that has a scanner. you cant get the codes with out some type of scanner.
Old 10-05-2004, 02:49 PM
Re: how to get "service engine" codes
thanks busa_4 for the info. the reason i was asking is because my friend has an impala, and he said that you could turn the ignition off and on 5 times, and a LED light would flash a morse-code-like signal. i was hoping an s-10 might have a similar trick.
Old 10-05-2004, 03:40 PM
i dont think you can do that with obdII. i know for sure you can do that with obdI.
Old 10-05-2004, 05:54 PM
sector95 sector95 is offline
Re: how to get
thanks.
I don't know if you have AutoZone stores where you live but around here they will down load your trouble codes for free (they typically use an Actron reader like you can buy). Check around at the bigger chain stores and see if they provide this service.
Good luck...
Mike
Old 01-20-2005, 01:49 AM
ups88daj ups88daj is offline
Have you found your problem.. MySdime 2.2 did the same thing awhile back. It ended up being the Secondary Air Injection pump. The unit went bad and one of the vacumm lines came off making it sound like a hopped up lawn mower.
Old 01-20-2005, 05:00 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
yeah auto zone , pepboys , any carquest, advanced auto they all do this for no charge.
Old 01-27-2005, 03:32 PM
silkydub silkydub is offline
Autozone has a key they will give to you to make the engine service soon light blink they tell you what the code is after you insert key into the module under the dash by the parking brake. I hope this helps
Old 01-27-2005, 04:00 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Re: how to get
does that work on obdII??
Old 01-27-2005, 04:21 PM
chris15706 chris15706 is offline
Re: how to get
I think my s-10 is doing the same. Did it make a loud fan noise?
Old 01-27-2005, 06:32 PM
Fireplug Fireplug is offline
You can use a (key jumper wire) only on OBD1 Systems pre 1996 after that most all cars are OBD2 and a scan tool or code reader is the ONLY way to get codes out of the computer
