Old 10-05-2004, 12:37 PM
steventheseeker steventheseeker is offline
Replacing fuel pump in 95 s10 blazer
My 95 s10 blazer will not start and I believe that the fuel pump went out. I can't hear the fuel pump turn on when I try to start the car. I'm going to replace the fuel pump but is this a hard thing to do and exactly where is the fuel pump? I was told that in chevy's its actually in the gas tank.
Old 10-05-2004, 09:30 PM
wilfie27 wilfie27 is offline
Re: Replacing fuel pump in 95 s10 blazer
It is in the tank but did you check your fuses and wiring first. That would be a lot easier fix than dropping the tank.
Old 10-06-2004, 02:10 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
check Fuses, check fuel pump relay and THEN check the fuel pump.
Old 10-06-2004, 04:19 AM
is there an echo ?
Old 10-06-2004, 11:08 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Replacing fuel pump in 95 s10 blazer
Originally Posted by wilfie27
is there an echo ?
Only in your head.
