Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 10-05-2004, 11:41 AM
dbird dbird is offline
Unhappy electric mirror switch replacement
Has anyone ever replaced the mirror switch for a 2000 Passat? Someone broke off the mirror adjustment knob at the carwash (and failed to tell me about it)...I noticed it after it was way too late to complain. Anyway...I bought a new switch...but it doesn't seem like it's that easy to pop out the old one without doing some serious damage to the palstic around the door latch. Any advice would be much appreciated!!
Old 10-19-2004, 08:53 AM
hobbs365 hobbs365 is offline
Send a message via AIM to hobbs365
I had the same problem on a Jetta i previously owned, i ended up taking the whole door panel off to replace it. I would like to know where you bought the part from though because now i have the same problem in my 99 Passat
Old 11-18-2004, 01:28 PM
Re: electric mirror switch replacement
The part was available at the dealer...but it was about $30 if I remember correctly. Might be able to get it cheaper on-line somewhere...
Old 11-26-2004, 02:55 PM
Aditz Aditz is offline
O.K. I hope this reply is not too late... Those knobs are really easy to breake. I've got the knob from the dealer as you did and replace it myself. How ? Easy..you don't have to take the whole pannel off!!!
The dealer was gonna charge me £40 ...ha ha ha!!
Here is the deal, you take a electric screw driver and a screw, screw the screw ( not too deep!!) into the knob unit and the pull from the screw the whole thing out(be aware: hold the door handel unit as it might come out too). That's how i did it ..simple..you don't need the old one anyway...so distroy it !!
If you want anymore tips ..get in touch!!
Old 02-24-2005, 11:23 AM
sam_eer sam_eer is offline
Hi
I have bettle 2000. and my power mirror switch broke, i guess its nothing unusal. i bought the switch but having hard time to install it. i dont want to pull off the door panel. i am tryin to pull the knob but its but the cover is made of plastic and i am afraid i am gong to break it. if u have any solutions or if u can suggest where can i look for one please do so.
thanks
Old 02-25-2005, 07:15 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
HAHAHAHahhah!
there is one philips screw that holds the door handle/mirror switch pannel on to the door pannel and its all also held on by clips. You need to remove the whole door pannel (2 screws on bottom and 3 bolts behind handle).
Old 03-05-2005, 08:44 AM
mickee mickee is offline
Send a message via AIM to mickee
I have the same problem with my '99 passat. Are you sure about the screw Idea? Wow. I've been missing the part for years now. I don't even know how it broke off.
