Old 10-05-2004, 09:20 AM
someguy000001 someguy000001 is offline
'97 Blazer door sag
The driver's side door on my Blazer sags a bit when it's open, and the rear lower edge is starting to hit the frame and chip off paint when I close it. It doesn't always slam shut on one go, and when I open it it drops about a half inch. I looked at the hinge pins, but there doesn't seem to anything that's adjustable. Anybody have this problem and know of a fix or estimate for repair?
Old 10-05-2004, 10:05 AM
Mikado14 Mikado14 is offline
Re: '97 Blazer door sag
You need to have your door pins and bushings replaced. The longer you continue to use the doors the less likely the pins and bushings will repair it for you will end up elongating the holes that the bushings go into. Pins and bushing sets for both hinges should be under $20.
Old 10-05-2004, 02:27 PM
Thanks, that looks like exactly the problem. Unfortunately, I can see that the holes are already enlarged. I guess I'll have to file this one under the 'not worth the trouble' category.
thanks again for the speedy reply.
Old 10-06-2004, 03:17 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yes it is worth it.
Don't be lazy and fix it. New pins and bushings will at least stop it from rubbing.
Old 10-06-2004, 03:53 PM
Wink Re: Re: '97 Blazer door sag
Originally Posted by BlazerLT
Yes it is worth it.
Aw shucks... Ok I'll do it
Old 10-06-2004, 03:57 PM
BlazerLT's Avatar
AF -Advisor
kew, MOVE IT!
Old 10-06-2004, 08:03 PM
YES!!! DO IT!!
The elongation that you are seeing is more than likely the bushing.
Old 10-07-2004, 04:09 AM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
From what I hear, the process for doing this requires a spring compressor tool. I heard the spring part is a pain because it shoots out and hits you in the eye... Well, maybe. The spring is pretty tight in there. Can anyone who has done this before give any hints or a degree of difficulty?
Old 10-07-2004, 04:13 AM
BlazerLT's Avatar
AF -Advisor
I don't think you have to remove the spring to do the bushings and pins.
Old 10-07-2004, 08:12 AM
Alexxn 00 Si Alexxn 00 Si is offline
Huh ??? You most certainly HAVE to remove the spring to install the pins/bushings.....did both my driver and passenger side.....not that big of a deal if you have jackstands and a buddy to help.
2005 Chevrolet Silverado 2500HD Ext cab
Old 10-07-2004, 12:02 PM
chcknugget's Avatar
After removing the spring, do you just tap the pin and bushing out with a hammer? Also, I heard you do the upper pin/bushing first.
thanks!
Old 10-07-2004, 12:21 PM
I did the bottom ones first. Take 2 jackstands and put towels on them to hold the doors. Also have someone help. Before you do anything put some duct tape along the edge of the fender to protect the paint. I used an air hammer with a flat end on it to pop the pins out past the knurl. A hammer will work also. Once you get everything out it's easiest to use a nut and bolt with washers to "draw" the bushings in. HTH
Old 10-08-2004, 09:11 AM
Don't forget, there is also a snap ring on each pin and the bushings are two different sizes.
Old 10-08-2004, 09:54 AM
Ahh yes thanks Mikado14 for adding that !
Old 10-10-2004, 02:57 AM
chcknugget's Avatar
hahaha, just my luck!
Today the spring in the door that needed its hinges replaced just shot out. Seriously! The little spring compressor bar was somehow on the other side of the little bushing too. It was crazy.
I guess I'll be getting to that door project a little sooner than expected...
