Old 10-05-2004, 06:11 AM
Future303 Future303 is offline
Astro jumps when shifting after Startup
Guys, I have a weird issue with my dad's Astro.
It's a 93 V6 model Passenger Van with Automatic Transmission. Van will start normally but when switched to any gear (Reverse or any of the Drives) the transmission will jump, and particularly when going to Drive or Overdrive it will be a hard jump.
I got the Tranny Fluid changed, and the mechanic says that this is normal, but I'm still afraid the tranny will be damaged.
Is there anything I can do about it? We literally have to warm up the Van for 10 mins to minimize it. Anything else we can try?
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 10-07-2004, 12:07 AM
Guys. your infinite knowledge and wisdom has truly left me speechless!
Old 11-11-2004, 07:22 AM
Re: Astro jumps when shifting after Startup
You guys were a big fuckin' help! God this forum sucks
Old 12-01-2005, 05:40 PM
Kanelr Kanelr is offline
Exclamation Re: Astro jumps when shifting after Startup
it may be the motor mounts-does it only occur right when you put it into gear and if you floor the gas pedal?
Old 12-01-2005, 07:49 PM
astro fan astro fan is offline
Re: Re: Astro jumps when shifting after Startup
Check mount at rear of tranny and U joints on driveshaft.
Old 12-02-2005, 11:51 AM
drew300 drew300 is offline
Did it jump before the oil change?
Was the filter changed?
Is it the right oil?
Maybe check the oil for dirt, or if it might be the wrong oil, change it again.
And thanks for swearing
Old 12-06-2005, 12:27 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
when the vehicle is cold starting it will jump because it normally idles higher to get the engine up to temperature. Next time see if it happens when the vehicle is fully warmed up.
