Old 10-05-2004, 12:34 AM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
Red line problem
Hey fellas,
I put 3.73's in my 00 Z about 3 months ago. I also don't have the right tire size on my car they are to small. Well i noticed that when i would race it in D it would not go all the way to 6200 rpm it would do about 5700. I programmed the computer with the Hpp3 to the 3.73's and it fixed the problem. Now recemtly i programmed the computer to my tire size and the problem has come back. it only goes to 5700 rpm in D. I can make it go all the way if i manualy shift it but id rather not. Now my tire height is only 24in which is way short but i figured that having the computer programed with all the info that it would let it go all the way to 6200rpm. Any body have this problem? Or have any ideas what it is. My guess is the tires are way to small.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 10-05-2004, 12:39 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Red line problem
The 4l60-E isn't meant to shift manually infact you could cause some serouis damage by shifting that way and Our cars have been known for having the Tach climb slowwer than the actual engine is doing. If you do a google search you will find that alot of owner's have noticed this but since you stated it was operating normally without the tires adjusted I would say just program it back for the old tires I doubt it will be off by that much but I'm sure you can find out a exact number online
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-05-2004, 06:11 PM
z28 boy's Avatar
It still chirps the tires on the shift and everything it just doesnt redline the way it used to. So i don't know if i am losing power or the tach is just off like u said.
2000 Z28 A4:
Old 10-05-2004, 06:14 PM
FormulaLT1's Avatar
Fight the powwa!!!
Just set it back for the old tire and see if it goes back to the way it was.
Old 10-05-2004, 06:58 PM
Dober89 Dober89 is offline
Does it even make more power at 6200 than at 5700?? My car redlines at 5500 but the power stops climbing around 5000.
Old 10-05-2004, 07:38 PM
z28 boy's Avatar
But when it shifts u want the car to drop u in the next gear right in ur power band. If u don't go high enough before shifting then u will land under ur power band.
2000 Z28 A4:
Old 10-05-2004, 08:17 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Re: Red line problem
Nicely put, I should be asking you for advice. But If your churping the tires on the upshift you must be hitting your next gear pretty close to your torque curve. although I would progam it down for the other tires and just set a mental note its slightly off.
