Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 10-04-2004, 09:54 PM
GTpaul86 GTpaul86 is offline
Send a message via AIM to GTpaul86
Info needed
i have my 86 gt and the gauges are starting to mess up i was wondering if i put auto meter gauges in it will it run right not reading water temp or oil press and do i have to buy speacial gauges to go from the cab back cause i know its alot farther then a noraml car any help would be great
Paul
Old 10-05-2004, 05:19 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: Info needed
The temp gauge sensor is actually separate from the computer's temp sensor(the computer sensor is on the 'stat housing and the gauge pickup is on the rear cylinder head), and the computer doesn't look at oil pressure at all, so don't worry .
The length isn't really an issue as long as you buy gauges with electrical sending units(they use wires instead of a sealed copper tube), you can run the wires as long as you need. Most aftermarket gauges come with a sending unit, so you can just remove the old factory ones and throw them away. The factory gauges never were very accurate (this is true on most older cars) and with age they get even worse.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 10-05-2004, 08:24 PM
Re: Info needed
cool thanks man
Old 10-07-2004, 09:06 PM
Re: Info needed
oops, I made a boo-boo, the computer DOES check to see if there is oil pressure during cranking before it will allow the engine to run. It's just one of those little safety mechanisms car makers designed for people who don't know how or are to lazy to read an oil pressure gauge. There's a easy way around this, and I will tell you what it is, but first I need to look at the underhood wiring diagram in my shop manual, which has wandered off somewhere...
Wanted to buy:
Old 10-08-2004, 01:45 PM
Re: Info needed
what about an oil filter plate that you have multiple areas for oil acess. i dont mind the elec. water but i want a mech. oil press just feel better
Old 10-08-2004, 02:03 PM
Re: Info needed
and oil temp. does anyone know where i can get all this stuff CHEAP!
Old 04-08-2005, 07:04 PM
Barker Customs Barker Customs is offline
Re: Info needed
i have an 86 gt also and i put in aftermarket guages. i have an electic water temp and a mechanical oil press as well as a tach i hooked the tach up to the MSD box and its about 200 RPMs off the old on i ran all the wires through a hole right above the ecu other then that every thing is fine took the factory oil press sending unit out and my car starts and runs fine
