Old 10-04-2004, 08:03 PM
CWF CWF is offline
Dimmer Switch Relay?
Where's the dimmer switch relay located? Above the gas peddle?
Old 10-05-2004, 04:09 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Dimmer Switch Relay?
what year car, and do you have auto-dimming headlamps?
Old 10-05-2004, 04:43 PM
CWF CWF is offline
O.K. I learned something today. It's the dimmer switch that dims the lights on the dash, and not the dimmer switch that controls high and low beam.
I just bought the car, and the guy told me the dimmer relay switch needs to be changed, which he had already bought. Well it's not that thank God. It's meshed up there on the steering columb.
What I'll do is check to see if the light bulbs are burned out. I don't know if there is a relay for these or not. The fuse is good. The dash just will not light up. All other light work.
The vehicle is a 1994 Lumina APV
Thanks
Chuck
Old 10-06-2004, 09:08 PM
CWF CWF is offline
Are the dash lights tied in somehow to the dimmer switch relay?
When I push the headlight switch on, the radio, and heater lights go out. Shouldn't this be in reverse? The dash lights refuse to come on. Is there something better than the Hayes Manual?
Old 10-06-2004, 09:14 PM
djmoore85 djmoore85 is offline
Send a message via Yahoo to djmoore85
I always found a chiltons manual to be more helpful in electrical issues. also test all relays inside and under hood. you would be surprised how one thing can affect something not even related. i learned that the hard way on a couple cars
Old 10-07-2004, 09:16 AM
CWF CWF is offline
I'll check one out DJ.
Thanks!
Old 12-17-2004, 10:11 AM
surgemaster surgemaster is offline
Ditto on the Chiltons manual. The dimmer switch can cause all kinds of electrical problems when it goes bad. Replace the switch and dimmer and you may find that the electrical problems disappear. I had a short that was knocking out the driving and running lights. I found a good mechanical and he replaced the switch and no problems since.
