Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-04-2004, 07:59 PM
pachino1313 pachino1313 is offline
saturn performance
I also got a new 1999 saturn sl2 i got for $3000 i want to know everything possible to do with the car from suspension to rebuild to turbo im planning on spending 10k please tell me what 2 do 2 bring out the most horsepower for lower prices then the best order to do the engine mods it would be much appreciated
Old 10-04-2004, 08:34 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: saturn performance
you want everything? ok...
http://www.spswebpage.com
http://www.saturnfans.com
http://www.turbosaturns.net
http://www.saturnmotorsports.com
http://www.qksltwo.com
http://www.saturnspot.com
http://www.differentracing.com
and thats just off the top of my head, didn't even check my bookmarks
Old 10-05-2004, 08:50 AM
SabreKhan's Avatar
SabreKhan SabreKhan is offline
The middle pedal is bad
www.twistecproducts.com -- They have all but discontinued their 1.9L Saturn fabrication, but they still have lots of leftover parts for really really cheap. Get 'em while they last.
Look at the teeny picture of my car!
2004 Impreza WRX (SCCA DS 519)
2000 Saturn SL
Old 10-05-2004, 08:57 AM
SabreKhan's Avatar
The Saturn is a lightweight, easy to work on platform for modification. For HP gains, I'd work first on the breathing: intake and exhaust. If you want to go all out, port and polish the headers. Get some high-flow spark plug wires, an ECU, and if you're really looking for HP, bolt on a turbo. They respond quite well to turbos. The suspension is probably where you want to focus, though. Get a good set of coilovers, a rear sway bar, and a front strut tower brace for sure, but also probably some bracing in the front and rear would be good. The car definitely needs new wheels and tires. Even the factory alloy wheels are too heavy. Some sixteen inch lightweight wheels with low-profile tires will help handling quite a bit. To get rid of wheel-hop and improve torque seep, put some solid motor mounts on it. The mounts will make your launch feel so much better. If you can afford a body kit, put a little bit of a skirt on it to help airflow, but unless you're going to be racing the car on a road course, a wing is just added weight.
2000 Saturn SL
Old 10-05-2004, 12:43 PM
http://www.scdyne.com - supercharger
Old 10-07-2004, 08:26 PM
hey guys tnks a lot for your performance help i have found everything i need for a new motor.
