Old 10-04-2004, 07:59 PM
tyko909 tyko909 is offline
Send a message via Yahoo to tyko909
Unhappy Muffler is hot!!!!!
I dont know what to do next. I have replaced the turbo, water pump, thermostat and, headgasket and I am still overheating. problem starts almost immediatly after startup. what else can I do?. the car compression tests fine and has good lines on everything. I dont know what else to check or replace, the fans turn on and everything? Please help me!!!!! oh yeah the muffler gets hotter than, ummm, errrrr, yeah, it gets hot.
Who needs speed when you push 155.8 dB.... I do!!!
6Bolt cyclone, 16g turbo, AWD, and a 5 speed
Old 10-05-2004, 09:40 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Help Me Please
Are you sure you don't have a big air bubble in the cooling system? Also, not to be a dick or anything, but how do you know for sure that you are overheating? There are 2 temp sending units on the thermostat housing (one feeds the ECU and one feeds the stock gauge). If you are going by the stock gauge, maybe your sensor is bad (mine went and was telling the ECU that my coolant was -20). Do you have a logger that you can check the ECU sending unit?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-05-2004, 12:11 PM
Mram76 Mram76 is offline
Re: Help Me Please
i had the same thing happen to me it turned to be the sensors...check ur sensors to make sure the read are right. i don't know what they are. check the manual or got to autozone....
Old 10-05-2004, 03:06 PM
shadowcste shadowcste is offline
Send a message via AIM to shadowcste Send a message via Yahoo to shadowcste
Re: Help Me Please
another thing that could be happening is the radiator being full of something check the front of the radiator make sure you didnt suck something up into the radiator fins especially if it is overheating at idle
Old 10-05-2004, 09:01 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Help Me Please
did you make sure the head gasket is on the right way... its pretty easy to put it on upside down. that right there could allow the exhaust gasses to heat the water almost immeadiatly apon start up either that or not properly torqued down head bolts...
