Go Back   Automotive Forums Car Chat > Ford > Club Wagon
Old 10-04-2004, 07:34 PM
mfoldone mfoldone is offline
Air bag light flashing
my 1997 clubwagon airbag light is flashing code 47, what do i need to do to fix this problem without going to the dealership?
Old 03-11-2007, 09:26 AM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: Air bag light flashing
airbag codes in the 40's indicate a sensor problem. Usually it's a bad ground or a fualty sensopr. I would reccomend you disconnect the battery, remove the sensors (2 or 3) mounted on the radiator core support and clean the mounting area, removing any rust that has built up. then remount the sensors and reconnect everything. Older Ford airbag systems self diagnose and will clear fault code withoutr a scanner. If the probelem persists, you may need a new sensor
