Old 10-04-2004, 06:34 PM
scriptures4life scriptures4life is offline
Question Siezed Calipers - Can they be unseized?
I took my metro into Canadian Tire and they said my front calipers are siezed. Can I un-seize them, or should I just replace them? FYI, the rotors are in need of replacement as they are too worn to be turned and everything is prety rusted down there.
Thanks
Danny
Old 10-05-2004, 04:49 PM
joey71 joey71 is offline
I do not think they can be unsiezed-- if they are siezed now why would you even want to try and unsieze them??Has the car been sitting?? if so what kind of contaminaits are in the caliper piston?? I grabbed calipers for mine and they were like 23.00 a peice @ auto zone the rotors are not that expensive either-- I would just change everything-- It is what stops your car, so I wouldnt skimp.
Old 10-10-2004, 11:05 PM
kevin206 kevin206 is offline
Send a message via Yahoo to kevin206
Re: Siezed Calipers - Can they be unseized?
cheap to replace...but can be unsiezed probably. You could unbolt calipers 1 at a time and try to apply brakes and see if they move....or squeeze them back with a c-clamp. That may break them free. if you can get the piston out of the caliper, you could clean them up and turn the o-ring inside out, put it back together and you have a rebuilt caliper.
Old 10-15-2004, 11:44 AM
mcalvo's Avatar
mcalvo mcalvo is offline
Send a message via MSN to mcalvo Send a message via Yahoo to mcalvo
Script:
With some patience, you can fully unseize the calipers. Even do, you should seroius consider to replace them since all the rust near by could ¡ndirectly affect some other pieces of your brake system. I guess you would not like to miss a red light because your brakes do not respond.
MC
