94 explorer
i have a 94 explorer xlt the headlights are going in and out.. i have checked all of the fuses and grounds and that all seems to be ok.. i dont want to take it to a dealer and get hosed if it is something as simple as a loose wire somewhere... any suggestions?
i'm having a similiar problem - i bought fog lights and wired them into my headlights so they turn on when the headlights do. ever since i did that - usually 5 minutes after i turn them on they start to flicker, causing the headlights and fog lights to both flicker on and off. i too checked the ground and the power wire connection and all seems ok.
i even put in an in ground fuse, but it still happens. so we're both having the same problem. any suggestions??? |
the other day i was messing with it because the interrior lights were having an issue too.. so i messed with the toggle switch.. and that seemed to get the interrior lights better.. so now i'm going to completely tear the dash apart and get a good look at the switch.. maybe there is a loose connection there..
Re: 94 explorer
problem in the switch?...could be, but it wouldn't be the diagnoses to my problem since it didn't start doing that til i wired in the fogs to the headlight. but let me know how ya make out.
jeff |
Re: 94 explorer
I also have a 94 Explorer XLT that has flickering headlights.
I would like to know what you've figured out so far... Thanks, Gray |
replaced the switch ($30 at your local ford dealer) .. problem solved
