Old 10-04-2004, 02:04 PM
skitt123 skitt123 is offline
'92 Grand Voyager wont shift out of low gear
I don't think it's the transmission itself. It starts out fine, in first, you feel it shift to second, then third, but instead of going to 4th, it slips back down into second, there's a slight jolt, and then it's stuck there. Won't shift up or down until you turn the van off and then back on. Also, the reverse just went out one day.... no problems before that, just went out. Any suggestions?
Old 10-07-2004, 02:34 PM
Re: '92 Grand Voyager wont shift out of low gear
bump
Old 10-09-2004, 11:49 PM
nipsirc nipsirc is offline
have the tranny serviced...
change the oil, gasket and filter.
had the same problem but went away as soon as I had the service done.
Old 10-10-2004, 01:20 AM
trannyman52 trannyman52 is offline
the controller is "faulting" the trans to "take home" mode,,,,,,for some reason,,,either electrical or mechanically,,,,, get it checked out!!
Old 12-19-2004, 11:07 AM
cmunch cmunch is offline
If you have not already got this fixed there is going to be one of two problems, 1- one of two speed sensors on the front of your trany is shot giving the comp and error, or 2- the comp. is picking up a pressure sense from one of the four gears ( probably the overdrive gear) that is out of spec. , when either of these two things happen the comp. send the transmission into "limp home mode" this lock the trans in second gear allowing you to limp the van to the nearest repair shop. My guess is that you have problem number two and it was caused by the snap ring breaking holding the o.d. clutch pack together. If your trans has not already cooked itself, you need to gear up to have it rebuilt.
