Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 10-04-2004, 01:41 PM
VashcivicSi87 VashcivicSi87 is offline
Send a message via AIM to VashcivicSi87
Exclamation white smoke
hey guys i got a question. theres white smoke coming from either the sparkpulgs or the header and the pgm-fi light is on but there is no code lit up on the box. does anyone have any idea of what my be causing the smoke or the pgm-fi light to be on? also ive checked the lines from the map sensor and other vac lines as well. please help me out
Old 10-04-2004, 02:56 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: white smoke
The first thing you need to do is pull your valve cover off and check to see what color your oil is. If it's milky white, you're burning water meaning your head gasket is blown. I don't have my book at the office with me, so I can't remember what would be causing the pgm-fi light to be on. But defenitely check that and pull your spark plugs to see if there is oil deposited on them.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 10-04-2004, 08:27 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: white smoke
just pull the oil cap off and look at the bottom side. no need to pull the entire valve cover off
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 10-05-2004, 12:40 PM
ok ive checked the oil and its fine, im thinking that the smoke is coming from the gaskets between the header and the block but im not sure
Old 10-05-2004, 02:14 PM
Figori's Avatar
Re: white smoke
Then you might want to check your exhaust gaskets. And make sure the bolts are torqued down to specs.
Old 10-10-2004, 03:32 PM
LSfrankenstein LSfrankenstein is offline
Banned
Re: white smoke
white smoke indicates coolant being burned. definitely a gasket problem
Old 10-10-2004, 03:39 PM
kenarmy kenarmy is offline
Re: white smoke
iam trying to find the casting number of an 1993 chrysler lebaron engine it is an 3.0l v6 smpi sohc 8v engine can any one tell me wre to find it at thanks ken
Old 10-11-2004, 11:33 AM
87civicfranky 87civicfranky is offline
Re: white smoke
ummmmm ken my good ol chap.....THIS IS A HONDA '71-87 CIVIC/ CRX' FORUM........try to go to the the chrysler lebaron forum.......please dont hurt your self looking.......(saying it with love)...
