Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 10-04-2004, 10:42 AM
57ringo 57ringo is offline
changing water pump on a North *
Is there a place online I can get instructions on changing a water pump on my 96 Deville?
Old 10-04-2004, 03:42 PM
MarkC MarkC is offline
Re: changing water pump on a North *
Haven't been able to find any do it yourself car repair sites on the web. Best bet might be to buy a service manual on ebay.
Old 10-04-2004, 03:43 PM
Haynes Repair Manuals are sold at AutoZone I believe also.
Old 10-04-2004, 09:38 PM
check out this site, found it by accident http://www.alldatadiy.com/index.html
Old 11-11-2004, 08:29 PM
beegolden beegolden is offline
The Northstar is easy if you have the propper tool, I did mine without a tool and it took me over 2 hrs, with the waterpump tool it would have taken 10 min.
Check out Autozone if in your area they lend tools or if not try to rent a tool.
It is real easy you just take off the thermastat housing and the pump twist in and out.
Old 11-14-2004, 12:02 PM
DIGBY67 DIGBY67 is offline
Did you get the water pump changed?
I'm trying to change one on my Aurora (same set-up) and it won't budge.
I have the wrench (the cheapo Lisle) but it keeps slipping off and i'm not getting anywhere.
Anyone else run into this problem?
Am I missing something?
Digby
Old 11-14-2004, 08:00 PM
I did change mine by just a chisel I am lucky I did not damage the houseing, if you need more info try this other forum:
http://caddyinfo.ipbhost.com/
Good luck
Old 11-14-2004, 08:23 PM
Thanks beegolden for the link...I'll check it out.
I hear ya on the chisel...I'm paranoid about damaging something $$$$.
I'm going to try using a heat gun to warm it at the suggestion of someone from the Aurora forum.
Wish me luck...this car has been a driveway monument for over a week now.
I'll keep checking this thread to see if anyone else has run into this.
digby
Old 11-15-2004, 04:44 PM
tampaFD tampaFD is offline
remember the pump is like a left handed thread it twists to the right to come out. if you get in there and look you will see the ears that stop it from turning. and PB blaster is your friend
Old 11-19-2004, 08:54 AM
I haven't changed mine yet. I had rotary cuff surgery and that put a stop to anything for a while. I did buy the tool through Napa and talked to our tool rep that has changed them. He said they popped it with an air chisel but you have to take care not to bust the housing. I also talked to a guy that had to cut the old water pump apart because it was so corroded on the aluminum housing it screws into. They said be patient and careful. The rate my shoulder is healing, I'll be able to fix this in......November 05.
Old 11-19-2004, 10:58 AM
some pb blaster is your friend shoot both sides. a 1/2 inch air gun with a swivel will attach to the tool and fit just past the fender held upside down. coulpe of bumps and it's off. make sure you sre on the pump ears not the housing stops. clean the ridge and you are good to go
Old 07-16-2007, 06:35 PM
OleBones OleBones is offline
Autozone.com offers free online repair manuals but they recently updated their site so yours may not be available yet.
