Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 10-04-2004, 08:38 AM
rpk1204 rpk1204 is offline
Trooper starting hard when cold
Have a 93 Trooper S, 4X4, Manual Transmission, 125K miles. I've had this Trooper for 6 months and it has run great. Just this weekend, when cold, it has begun to start hard. Acts like air/fuel mixture is bad (on an old car, I'd check the choke - that's what it acts like). After it starts and runs for a minute or so, it's fine. Any ideas on what to look at first? No check engine lights are on.
Old 10-08-2004, 06:30 AM
rodeo02 rodeo02 is offline
Couple of blind guesses: 1) Bad idle air control valve (IAC), 2) bad fuel pressure regulator.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 10-08-2004, 10:07 AM
kplusten kplusten is offline
You may have water in your gas, esp if the car is not garaged, just from condensation buildup. Water is heavier than the gas and enters the injection system first, often causing a hard start. Two bottles of dry gas may mysteriously cure the problem, worked on my son's trooper.
