Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 10-04-2004, 08:28 AM
ceamerson ceamerson is offline
Rear window break light
How do i remove the rear window break light so I can tint behind it?
Old 10-04-2004, 09:14 AM
el es's Avatar
el es el es is offline
press firmly on the top of it and pull back about 1/2" it is kind of tough to do but essentially that is it.
eL eS
Stand by for heavy rolls as the ship comes about!
Photo gallery of Ye ol' Black Pearl
Old 10-04-2004, 10:06 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: Rear window break light
"Pull Back" means slide toward the windshield. Don't try to pry it up away from the deck or it WILL break. Push it down into the carpet about 1/4" and while maintaining pressure slide it toward the windshield. That will remove the trim. Underneath it you'll find the actual reflector assembly. It has a gasket on it that presses up against the glass to prevent glare. Remove the bulb by twisting about 1/4-1/2 turn and slip out of housing. Now look inside the trunk for the two silver/white tabs protruding through the deck sheetmetal. They should be directly under the rear edge of the housing corners. Push them both up through the deck to partially relaes the housing. The only thing left holding the housing in is a couple "slide" tabs and the carpet. With some carefull sliding and prying, you should be able to remove the whole thing without damaging the gasket. If the gasket comes loose, repair it with a contact cement. Don't tear it off thinking it isn't important. Without it, there is an awful glare from the light whenever you brake at night.
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
