Old 10-04-2004, 12:38 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
oil leak...
ohk i got a 1996 gs n/t compleatly stock
if im runnin around 80-90 mph i smell oil burnin real bad but i dont see a oil leak neone know wuts wrong :-/
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 10-04-2004, 12:45 AM
george536's Avatar
george536 george536 is offline
Re: oil leak...
it probably burns up on your exhaust before it shows up.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 10-04-2004, 12:46 AM
xavier3jr's Avatar
its gota be a very small leak because my oil gauge hasnt moved but i can smell it very easy inside the car
Old 10-04-2004, 03:06 AM
joemathews's Avatar
joemathews joemathews is offline
Re: oil leak...
Your oil gauge won't move unless you have a major, major leak. Like, quarts pouring out of your car. The best way to tell how much oil you're losing is to change/fill up the oil to the full mark on your dipstick, drive it around for a few days, then check again to see how much lower the level is. Make sure to check the car after it has been sitting for a while, not after you've just driven it.
1996 Eagle Talon
Old 10-05-2004, 09:48 PM
Squirr3l Squirr3l is offline
Send a message via AIM to Squirr3l
Hi, I'm new to the forums here but I saw ur post and wanted to find out more. You see, i'm suffering from the same problem. I have a 98 Eclipse GS and after my car gets up to regular operating temp. oil starts leaking. It's a minor leak from what I can tell because I'm not loosing vast ammounts of oil. However it is a real pain. The most I can tell is its comming from the rear of the engine on the drivers side. NOT the valve/rocker cover gasket. I've already checked and replaced that. Thats all the info I can provide. Can anyone shed some light on the subject??
Old 10-05-2004, 10:33 PM
o*HeR()'s Avatar
o*HeR() o*HeR() is offline
Banned
Re: oil leak...
full is the second notch right?
