Old 10-04-2004, 12:14 AM
95mustangGT 95mustangGT is offline
Send a message via AIM to 95mustangGT Send a message via Yahoo to 95mustangGT
i need help!
Well i just bought a 1995 mustang GT from my uncle.im haveing 2 problems with it one is when i drive it i hear this sound its like something is rattling or loose and i only hear it when im acclerating does anyone have any ideas what it could be.my second problem is sometimes it doesnt want to catch when i try to start it but when i try it the second time it will start,could it be cheap spark plugs or the timing?
Im a newbe so try to work with me.
Old 10-04-2004, 06:21 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: i need help!
Sounds like detonation. Could destroy your motor if not addressed. For starters, go get a good tune up set. Autolite plugs, good wires (MSD recommended by me) and a cap/rotor. Gap the plugs at .054, set the timing at 12 w/89 octane fuel, and change the fuel filter while you're at it. Could save you from buying an engine...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 10-04-2004, 06:22 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Well theres no way any of us can help you w/ your first problem, because tracing noises over the internet is impossible, sorry. Your second problem is somewhat normal. I know of a lot of cars that do that, that otherwise run fine. You may have a starter solenoid starting to go, however. I would have have someone take a look at it.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-04-2004, 06:27 PM
bigbob bigbob is offline
Re: i need help!
yeah i have the same problem with my 95 gt when i try to start it but it only hapens durring the winter here in detroit. hmm
Old 10-04-2004, 07:02 PM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
if it sounds like its not catching the first time and the seckond time it will it sound to me like there is a dead spot on you fly wheel, and i have a question the computer should retard the timing when it senses detination right, isnt that what knock sensors are for?
