Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 10-03-2004, 11:26 PM
tercelboy tercelboy is offline
Question Thought I knew what I was doing
Okay so i go to take my starter out that had been crapping out (click click...try again...click click...again...vrrrrooom). And I'm laying there on my back taking the whole thing off (i think) and i get one bolt off...but then go for the next and i have no clue how to get to it without taking a bunch of shtt off of it. So pleeease someone help... HOW DO I GET THIS THING OUT!!! I really need to know because i drive for a living and neeeeed my car, but don't have the grip to take it to the shop. thank you in advance
Old 10-11-2004, 12:04 AM
jimmy[the]gent's Avatar
jimmy[the]gent jimmy[the]gent is offline
what year is it ?? mines an 89 and its in a realy shitty spot square under the car to the left of the alternator you dont have much space to work under there but i bet if you try with a wrench and soft hands ul get it
dont try a wratchet under there lol
Tommy, you gonna let him get away with that?
Old 10-11-2004, 10:27 AM
Mine's a 95 and yeah it's under the car, right in the middle, above the exhaust pipe, over the axles, under the intake, next to the coolant hose, through the sensor wires....etc. etc. etc........ I've basically got to go at it from 3 or 4 different angle to get THREE FUCKING BOLTS off . Even after that I don't even see how the hell i'm going to get it out between the firewall and the exhaust and everything.
Old 10-20-2004, 10:55 PM
get a haynes manual..
Old 10-26-2004, 08:08 PM
Re: Thought I knew what I was doing
yeah...um...you show me a haynes manual for a 95 tercel and i'll show you nude pictures of satan
Old 11-30-2004, 09:51 PM
tubjub's Avatar
tubjub tubjub is offline
Send a message via ICQ to tubjub Send a message via AIM to tubjub Send a message via MSN to tubjub Send a message via Yahoo to tubjub
starter out
i have a 90 tercel /w the 3E motor and it was 3 bolts to remove starter, ( power wire, and two mounting bolts)... but it was a bit of a pain to wedge it out of where it is once the bolts are removed... the power wire can be done from under the car, and the two upper bolts should be able to be accessed from the top of the car, behind the engine... eiether with a ratchet or air ratchet, air will make your life much easier.
Old 04-29-2006, 07:30 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
http://cgi.ebay.com/ebaymotors/1994-...60608680QQrdZ1
Better than nothing...
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
