Old 10-03-2004, 10:50 PM
mgalvez mgalvez is offline
Question 92 cavalier runs worse after motor rebuild
I rebuilt the motor two weeks ago and ever since it has been hesitating at lower rpm's. The rebuilt included a new connecting rod, new oil rings, new connecting and main bearings, new gasket set, new plugs, and new wires. I heard it could be air intake control valve.
Old 10-04-2004, 02:52 PM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
Re: 92 cavalier runs worse after motor rebuild
definatly could be your air intake valve. check to see if it is stuck, maybe spray the shit outta it with some carb cleaner.. that works well for me to get that nastiness all off
Old 10-04-2004, 03:30 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
or IAC (idle air control) valve, located on the back of the throttle body, remove it and clean the hole...
Old 10-05-2004, 01:25 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, I just cleaned my IAC and man, what a difference. Remove it, make sure you don't ruin the O-ring and sparay the pintle and spring with carb or throttle body cleaner and scrub it gently with a toothbrush.
Rinse with the cleaner again and spray the hole in the throttle body with the cleaner also.
also take the intake off and clean the throttle body butter fly and make sure it is seating properly. You will see the IAC hole goes all the way through to the back so blow the carbon and gunk out of it.
Also, how do you adjust the timing on these vehicles?
Old 10-05-2004, 09:15 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
you cannot adjust the timing. The car has a distributorless ignition that is all computer controlled.
