Old 10-03-2004, 10:45 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
Master Cylinder going out?
Is there a way to test or find out if the master cylinder may be goin bad, cuz we have bleed my brakes quite a few times and they just feel soft to me for some reason. Cant figure it out. Or is it just that the Brakes on an LT1 suck.......
Just for the Stroke of it...
Old 10-03-2004, 10:49 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Master Cylinder going out?
maybe someone took out your brake pads and put marshmallows in as a joke.
Old 10-03-2004, 10:53 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
How far down are we talking ? do you get really close to the floorboard cause if so its most likely a bad master cylinder , air in one of the lines or cracked/broken hose. Also I have done my brakes a couple of times and usually right after you bleed the system for the first couple of days they feel kinda spongey but I asked around and this is normal.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-03-2004, 11:04 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Re: Master Cylinder going out?
Doesn't sound so much like a joke as try to kill you but you got me good with that one a couple of times now Geno.
Old 10-03-2004, 11:06 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
marshmallows aren't brake pads!?!?
omg, that's y i can't stop!!
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 10-03-2004, 11:56 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
such a better smell when u do hard brakign tho, plus have some chocolate ang graham crackers in the car and bam smores
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 10-04-2004, 02:14 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
so does this mean the ceramic pad smores that i have been making are wrong too?
*Better power-to-weight ratio than a C6 corvette*
Old 10-04-2004, 06:20 PM
BadAzz240's Avatar
I put new pads, slotted rotors, and steel braded lines all the way around, but you know the car stops a lil better now but not like it should, it felt this way even before I changed it all out. If I am at a stand still at idle, I can press my pedal all the way to the floor the car doesnt move but it will go all the way down. And like I said we have bleed it a couple times.....
Old 10-04-2004, 06:34 PM
FormulaLT1's Avatar
Fight the powwa!!!
And the fluid level remains the same in the reserve?
Old 10-04-2004, 08:30 PM
BadAzz240's Avatar
the fuid level is never low if thats what you mean.
Old 10-04-2004, 08:37 PM
FormulaLT1's Avatar
Fight the powwa!!!
I'm just asking if your sure you don't have cracked or broken hose somewhere that your not aware of because when I had a master cylinder in my Vette go my pedal would go all the way to the floor with very little resistance and the car would take forever to stop almost like there was no braking at all,.
Old 10-05-2004, 06:24 PM
BadAzz240's Avatar
I dont think this is the case cuz i never see brake fluid leaking anywhere. Also like I said the fluid level does not change so im thinkin its the master cylinder...
Old 10-05-2004, 06:28 PM
FormulaLT1's Avatar
Fight the powwa!!!
Well how did you bleed the brakes all those times?
Did you use hand vacuum way? or 2 person , 1 pressing pedal, 1 turning nut way?.
Old 10-09-2004, 11:00 AM
NINÅ's Avatar
NINÅ NINÅ is offline
Air Rises
Because air rises the best way to bleed them is by REVERSE BLEEDING.
REFUSE TO LOSE
