Old 10-03-2004, 09:21 PM
DAVEQ DAVEQ is offline
92 Lesabre still dies while driving
As I drive the engine will just shut off and when i try to restart the engine it will start and die again unless i let it sit for 5 mins or so then i can drive away until the next episode . I have replaced the control module under the coil pack and the crank position sensor . I noticed the solenoid on the emission canister ( a new one ) was clicking rapidly when the engine was running , is this normal ? . Any ideas ? .
thanks , Dave
Old 10-09-2004, 08:11 AM
3echo9 3echo9 is offline
Re: 92 Lesabre still dies while driving
Dave...I am no technician but I seem to remember reading that the ecm accepts info from the cps at under 400 rpm's. The cam pos sensor feeds the ecm data as well. A failed cam pos sensor can have the same results as the crank pos sensor. On my 92 Lesabre they are both in the same area so I replaced them both when I had this problem and I haven't had a problem since. Just a thought. Good luck.
Old 10-09-2004, 07:59 PM
buickmastermind's Avatar
buickmastermind buickmastermind is offline
Might want to check the coolant temp sensor and the oxygen sensor if the other things don't work.
