Go Back   Automotive Forums Car Chat > Mitsubishi > Lancer
Old 10-03-2004, 08:26 PM
kdavis kdavis is offline
Need Quick Evo Viii Help
i just got a greddy profec B boost controller and i was wonderin what stock boost is on an VIII and what i can safely turn it up to. Im runnin 19.5 right now. Thanks for the help
Old 10-03-2004, 08:27 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
Re: Need Quick Evo Viii Help
haha, you're keen, i didn't think it would like doing that continually?
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
Old 10-03-2004, 08:33 PM
hey sorry bud i just asked a question
Old 10-03-2004, 08:37 PM
TRD2000's Avatar
sorry... didn't mean to laugh or whatever, just 19.5 is a lot of boost to be running while you're finding out what to turn it up to... i'd dial it down a bit till somone can get you some proper advice, just in case. I suspect the boost is round 13-15 standard.
if you had a Subaru it might be dead by now.
Old 10-03-2004, 10:33 PM
gooseman1 gooseman1 is offline
standard boost for a stock turbo engine.. any engine... without adding any injectors or fuel.. nor lowering the compression rate is at about 0.5 - 1.2 bar... unless you do something to the fuel system and compression rate... stick to that range.
Old 10-04-2004, 08:49 PM
Stanimal Stanimal is offline
kdavis,
The EVO's stock boost pressure is significantly higher then most vehicles.
IMHO, 19.5 psi is a good starting point for the EVO8. Stock boost is 19.5 at 3500, tapering starting at 5K to 14-15 psi at red line.
You should be able to up it to 20-20.5 without significant upgrades. After that, I would start with fuel pump, clutch, turbo back exhaust and ECU.
Old 10-04-2004, 08:52 PM
TRD2000's Avatar
DAMN! thats one seriously tuned/stressed engine!
Old 10-04-2004, 09:24 PM
stanimal thanks alot for the help. Forums like this are a big help when your in a pinch
Old 10-05-2004, 11:43 AM
EvoCrazy's Avatar
EvoCrazy EvoCrazy is offline
Send a message via AIM to EvoCrazy
The Evos turbo is pretty big. I suggest you ask someone at lancershop.com they know a lot about there Evos.
Old 10-05-2004, 01:34 PM
TRD2000's Avatar
ummm wait, it's big but it spools up so early its making 19.5 at 3500rpm? sounds more like a little turbo to me, does anyone know what it actually uses?
Old 10-05-2004, 09:04 PM
its got a 16G, i do know that
Old 10-05-2004, 09:12 PM
TRD2000's Avatar
I Thought It Was A 4g63?
EDIT:
SORRY... I THOUGHT YOU MEANT THE ENGINE NOT THE TURBO
Old 10-06-2004, 12:14 AM
Here's a good starting point for more general info regarding a stock EVO8 from Car & Driver
http://www.caranddriver.com/article....rticle_id=4186
Here's a bit of info regarding the various turbos used in EVO's over the years.
Evolution 1
Turbo = TDO5H–16G-7
Nozzle Area (cm2) = 7
Exhaust turbine = Inconel (nickel alloy)
Compressor = Aluminum, 60mm wide
Evolution 2
Turbo = TDO5H–16G-7
Turbine = Inconel (nickel alloy)
Evolution 3
Turbo = TD05H–16G6-7
Compressor = Aluminum, 68mm wide
Evolution 4
Turbo = TD05HR-16G6-9T
Nozzle Area (cm2) = 9
Evolution 5
Turbo = TD05HR-16G6-10.5T (GSR)
TD05HRA-16G6-10.5T (RS)
Nozzle Area (cm2) = 10.5
Turbine = Inconel (nickel alloy), Titanium alloy (RS)
Evolution 6
TD05HRA-16G6-10.5T (RS/rs2)
Turbine = GSR - Inconel (nickel alloy), Titanium alloy (RS/RS2)
Evolution 6 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
Turbine = Titanium alloy for both RS/RS2/GSR!
Compressor = Aluminum, 65mm (gsr) - 68mm(rs) wide
Evolution 7
Turbo = TD05HR-16G6-9.8T (GSR)
TD05HRA-16G6-9.8T (RS/RS2)
Nozzle Area (cm2) = 9.8
Turbine = GSR - Inconel (nickel alloy), RS/Rs2=Titanium alloy
Evolution 7 GTA
Turbo = TD05-15GK2-9.0T
Nozzle Area (cm2) = 9.0
Compressor = Aluminum, 65mm wide
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM E8)
Turbine = USDM EVO 8 & JDM GSR =Inconel (nickel alloy),
RS/Rs2=Titanium alloy.
Evolution MR aka "8.5"
GSR = TD05HR-16G6-10.5T or TD05HRA-16G6-10.5T (Ti Alloy option)
RS = 6MT:TD05HRA-16G6-10.5T or 5MT:TD05HRA-16G6-9.8T
Nozzle Area (cm2) = 10.5 or 9.8(RS-5speed)
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels. As the engine exhausts in pulses, it’s supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. counter-clockwise (hence the R in the turbo name). The titanium-Alumnide alloy used in the RS/RS2 and some GSRS (factory option) has less inertia and thus spins up a little sooner and quicker. These titanium turbos can be identified by the A in their name.
IMHO, Inconel turbine compressors are tougher then their Titanium-Alumnide counter parts.
Old 10-06-2004, 11:48 AM
EvoCrazy's Avatar
Wow, thats good info.
Old 10-06-2004, 01:41 PM
TRD2000's Avatar
thanks stanimal, hey do you know who makes those turbos? TD0? is used by trust/greddy right? I thought mitsi actually made some turbos?
