Old 02-14-2002, 11:09 PM
dominate9 dominate9 is offline
Send a message via AIM to dominate9 Send a message via Yahoo to dominate9
fuel system parts
I am putting an AEM CAI on my 97 Accord EX and I was wondering if it you be advantageous to upgrade the fuel system as well. SOme of the parts I have looked at are the AEM fuel rail, AEM abjustable fuel regulator, B&M fuel gauge. What do you think of these parts? Are they worth it? Are there any other parts you recommend? THanks guys.
97 Accord EX Coupe (H22A)
_____________________________
18" Focal SD5
225/40/18 Kuhmo Ecsta Supra (712)
AEM Cold Air Intake
Walbro 255lph Intank Fuel Pump
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
Katzkin two-tone Leather
3 JL Audio 10W3s
Kenwood DPX-4020 Double Din
Old 02-15-2002, 12:57 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
that would be a waste of time and money
Old 02-15-2002, 08:27 AM
Why do you you say?
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 02-15-2002, 11:47 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
it would be a waste because your stock fuel rail is able to supply way more then enough fuel for just a cold air intake, or any given combo of bolt ons for that matter. you dont need an adjustable fuel pressure regulator because you dont need to raise your pressure for anything. your ecu is very well capable of compensating and adjusting fuel delivery for whatever bolt ons you decide to get. now if you had a big cam or some method of f/i and required a raise in static pressure it would be worth it but just some bolt on's, no. and a fuel gauge is not necessary unless your running high pressures to keep an eye on them. now run a turbo with a 12:1 rising rate and sure a fuel gauge would be nice although still not much use cause you allready know your gonna break the 100psi range.
Old 02-15-2002, 12:49 PM
drift's Avatar
to add, the B&M fuel pressure gauge is useless for anything other than determining idle pressure... cuz you cant hop out of the car, pop the hood, and check the system pressure while driving, unless you're on a dyno.
an in-cockpit fuel pressure gauge is a much more beneficial system for monitoring fuel pressure.
Old 02-15-2002, 03:13 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
The above saids it all. If you have some extra money and don't know where to spend, my pocket is a very good investment j/k. Anyway, I would upgrade the suspension system if not already did.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
1999 Jetta GLS 2.0 AEG Fuel system problem Probe '97 - '03 3 04-20-2010 11:24 PM
95 talon wont start - no fuel pressure eclipse787 Engine, Transmission and Drivetrain 2 05-08-2009 10:06 AM
HELP! - Problem - Fuel Economy/Fuel System jlbauer23 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 8 12-31-2003 11:15 AM
