Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 10-03-2004, 06:55 PM
pennysaver pennysaver is offline
turbo's
My wife has a 2001 passat turbo 1.8. She told me that it has been acting odd when she is at a stop sign the car idols up and down. More the she remembers in the past. I took it for a ride and I don't hear the turbo kicking in. Is there an easy answer or will I be shelling out thousands?? Thanks for any reply.
Old 10-03-2004, 07:05 PM
RACER D12's Avatar
RACER D12 RACER D12 is offline
Send a message via AIM to RACER D12
Re: turbo's
Well in the passat i dont think you eill feel the turbo kick in really. As to the idle thing I dont know.
Edit: thanks matt
Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows
Old 10-03-2004, 07:17 PM
i3o2Matt's Avatar
i3o2Matt i3o2Matt is offline
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
Re: turbo's
well...for one its idle...not idol...thats someone you look up to...lol as for the turbo...i'm not sure...
EDIT: no problem, man
Old 10-03-2004, 07:45 PM
HighRev87's Avatar
HighRev87 HighRev87 is offline
Banned
Re: turbo's
Ok I can help you about as much as the two ahead of me that said I dont know. I would talk to people in the VW forums.
Old 10-08-2004, 12:11 AM
bleedvw bleedvw is offline
Re: Idle & turbo problem?
for your idle concern you need to clean the throttle housing. this you can do yourself with and allen wrench for removing the throttle housing and some carb and choke cleaner. then you will need to have a throttle adaption performed. for this you will have to visit a volkswagen dealer or find someone that has the ross tech software. as far as the turbo concern there are many possibilities for that concern. hope this helps for the idle concern.
Old 10-08-2004, 08:45 PM
there also may be a vacuum leak causing the concern. check the large vacuum line by the coolant expansion tank at the intake with the vehicle running. the vacuum line runs to the brake booster good luck and let me know what you find.
Old 10-11-2004, 01:10 PM
harthouse harthouse is offline
I would also suggest cleaning your throttle body; it helped smooth out my idle. Other areas to check would be the vacum lines as already suggested and the MAF.
Old 11-14-2004, 05:19 PM
zoom14151 zoom14151 is offline
I'm having the same problem with my 2001 Passat. Did you have it fixed and what was the cause. My is acting like someone is hit the gas and the car jumps forward.
