Old 10-03-2004, 06:06 PM
Jaymes's Avatar
Jaymes Jaymes is offline
I have velvet-like paint surface
Hi, I just applied some Krylon Fusion onto my model, and in some places te paint is nice and shiny, but in some areas the paint is flat and velvet-like. What do you think is the problem? And can this be fixed with some rubbing compound?
Thanks
Old 10-04-2004, 05:19 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Velvet-like paint surface
the problem may be that you have sprayed some areas after previous coat allready dried. Some colours are realy fast drieing and if you don't cover entire model in one quick overspray this could happen. You will probably be able to remove that with compound but it could also happen that it won't help enough. I would recomand one more coat over entire model.
Sasa Jelic
SCALEMAKERS
Old 10-04-2004, 10:21 AM
primera man's Avatar
"P-Man"
Sounds like you havent got a even coat of paint on all the areas you have painted.
To much paint in some places and not enough paint in others
View All My Models Here.
Old 10-04-2004, 10:31 AM
Martbee Martbee is offline
Agree, too much or not enough paint. Too much can cause the same problem because it give the paint to do tiny bubbles that burst when the paint begin to dry so when you look at it, you don't see the bubbles because they burst but the effect is a velvet kind. Check if the velvet is on the corner of the pieces/body... and if the plane surfaces are cool then I must be close to the answer. Rub n compound should do the trick.
Old 10-04-2004, 11:56 PM
Jaymes's Avatar
thanks for the help guys. I think the problem was that it dries too fast, since Fusion supposedly bonds w/ the plastic or whatever. I'm not buying this shit again lol
Old 10-05-2004, 12:52 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Good thinking, i've used that fusion before and had terrible result's.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 10-05-2004, 01:24 AM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
It sounds like you didn't use any primer? which may cause this problem.
