Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-03-2004, 03:07 PM
Savior1974's Avatar
Savior1974 Savior1974 is offline
Wierd howling noise comming from my engine bay
Ok now something is making a low pitch wistling noise. I think it's comming from the drivers side under the engine bay, maybe alittle towards the middle of the car or drivers side, some where in that general area. But anyways, when driver the car, and the engines winding up, I here a whistling noise until I here the turbo spool, then the turbo drowns out the noise but it's still there. Riverside Mitsu said it could be my altenator howling but I don't know. What do you guys think it is?????? Oh yeah, add a Mustang GT and a 350z to the kill list
1998 Eclipse GSX (Sold)
Act 2600, Apexi 3" downpipe, 3" exhaust, Hks 3"-5" muffler, Greddy TypeS BOV, Autometer Boost/Vac & Air fuel Gauge, Garrett T3/T4 60-1 turbo (Only boosting 15 psi) Tial 38mm Wastegate, Spearco FMIC, Greedy Profec B2, HKS Turbo Timer Type, Dejon Intake/K&N Air Filter, DSMLink, Eprom ECU, 950cc Fuel Injectors, Walbro 255 HP Fuel Pump, Aeromotive FPR, Drilled/Slotted Rotors, B&M Short Shifter
Old 10-03-2004, 03:18 PM
joemathews's Avatar
joemathews joemathews is offline
Re: Wierd howling noise comming from my engine bay
Could be the water pump going bad. Keep a close eye on your temp gauge, and if it rises past halfway, you know you've had bearing failure of the water pump, and pull over.
1996 Eagle Talon
Old 07-09-2008, 08:34 AM
bob02909 bob02909 is offline
2001 dodge grand caravan 3.3 engine, 2wd. When I shut the engine off the altenator is making a winding down sound. I looked into the altenator and on the right side there is a propeller that continues to rotate and this sounds like the the winding I hear. When the engine is shut down the propeller only turn for about 4-5 seconds. Is this a sign or warning of a serious problem? Do I need to replace the altenator.
Old 07-09-2008, 08:41 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Hi. Couple things.
-This is a Eclipse, Talon, Laser forum. 89-99. Please post in the appropriate section.
-This thread is almost 4 years old. Don't bring back old threads from the dead. I understand you probably searched on Google or something and came across this. But please pay attention to the sections and thread date.
Thread will be locked by a mod. In the meantime...
The alternator spins with the motor. So when motor turns off, the alternator will stop spinning. Check the belt and see if it's torn up or worn down at all.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Closed Thread
